16 years agoVariable in state Machine going Crazy (VHDL)
OK here is the code for my state machine. I am using it to control a serial multiplier in my circuit/
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity seq_mult_stateMachine is port(clk, reset, start : in std_logic; load_multiplier, shift_multiplier, load_multiplicand : out std_logic; reset_product, load_product, shift_product : out std_logic; done : out std_logic; the_state : out std_logic_vector(1 downto 0); -- for debugging purpose only counter_out : out std_logic_vector(3 downto 0) ); end entity seq_mult_stateMachine; architecture seq_mult_stateMachine_Architecture of seq_mult_stateMachine is type theStat is (S0, S1, S2, S3); signal present_state: theStat := S0; signal next_state: theStat; signal counter : std_logic_vector(3 downto 0); begin seq: process (clk) is begin if(rising_edge(clk)) then if(reset = '1') then present_state <= S0; elsif(reset = '0') then report "reached here"; present_state <= next_state; end if; end if; end process seq; com: process(start, present_state) is begin load_multiplier <= '0'; shift_multiplier <= '0'; load_multiplicand <= '0'; reset_product <= '0'; load_product <= '0'; shift_product <= '0'; done <= '0'; -- using signal the_state for debugging case present_state is when S0 => the_state <= "00"; when S1 => the_state <= "01"; when S2 => the_state <= "10"; when S3 => the_state <= "11"; end case; -- case present_state is when S0 => if(start = '1') then --Initializing load_multiplier <= '1'; load_multiplicand <= '1'; reset_product <= '1'; counter <= "0000"; next_state <= S1; else next_state <= S0; end if; when S1 => load_product <= '1'; counter <= counter + '1'; next_state <= S2; when S2 => shift_product <= '1'; shift_multiplier <= '1'; if(counter = "1111") then next_state <= S3; else next_state <= S1; end if; when S3 => done <= '1'; next_state <= S0; when others => next_state <= S0; end case; counter_out <= counter; end process; end seq_mult_stateMachine_Architecture; When I implemented it, it did Not work correctly. Thus I was forced to put the_state and counter_out signals for debugging purpose. When I run the simulation in Quartus with the other blocks and put the Start input, the output is shown in the Attachment. Problem: My 'counter' variable goes crazy once the state S1 is entered, it keeps increasing regardless of the state being changed and finally I get the error of setup time violation. It should change ONLY when the state changes right? thats how I wrote the code. Please tell me why this is happening I have used I integer before but the same result. http://www.alteraforum.com/images/icons/icon9.gif1 Reply
It's no reasonable VHDL code. You are implementing a counter in an asynchronous process. That doesn't work. A counter must be implemented in a synchronous process, in other words, it needs an edge sensitive condition to infer registers rather than combinational logic.
