16 years agoUsing the more port which exceed limit
Hi, I am designing a schematic design with the more ports.But When I want to make a symbol file, the error is coming:" It has more ports which exceed limit" How can I solve this problem or a...
16 years agoThe error is due to the limitation IO of your FPGA. Try to reduce the port or change to FPGA device which has more ports than you've defined.
