14 years agoUsing SDRAM
Hi guys, am really new to NIOS and Qsys/SOPC. I am doing a project where I would need to send an image from the PC to FPGA and save it in SDRAM, then read the image from SDRAM to do image proce...
14 years agoDo all the configuration/setup stuff in Nios. You can use Nios II/e, since it will be more than enough for this task. Then do the UDP packet handling in hardware. As I said - I do the same and it works perfectly.
