FrogWeapons
6 years agoUsing "remote" configuration mode in "standard" configured FPGA
I have a design which is updated remotely using the Altera Remote Update module. To make this function correctly I need to set Assignments->Device->Device and Pin Options->Configuration Mode to "remo...
- 6 years ago
The setting is intended to let Quartus know that possible remote update will be happening in this design. I dont see any downside here.
YuanLi_S_Intel
6 years agoYes, if you are using it with remote update, you should change it to remote.
- FrogWeapons6 years ago
My question was more: what would happen if you enabled the "remote" configuration and had an Intel Remote Update in your design, but did not necessarily intend to use it to update an application. Is there any downside to having it there?
