15 years agousing printf to print alt_u32 data
Hello, I am trying print the result from a FFT calculation using DMA. However, I am not sure how to use printf to accomplish that. I suspect tha it would look something like this: alt_...
15 years agoThe % format codes are somewhat a C language standard. Although printf() actually is a library function and is not strictly related to the language itself, almost every compiler/C tools defines the printf function and these formats in the exactly same way.
IMHO there is no need for extra formats for alt_xx type, since they are simple integer types. So you will always use %d or %x depending if you want them displayed in dec or hex. You could possibly use %f for float format but this makes no sense for integers. Maybe you'd like extra format directives, i.e. %04x for printing 4 digits and padding with zeros on the left. Example: alt_u32 a; a = 100; printf("%d", a); displays "100" printf("%x", a); displays "64" printf("%f", a); displays "64.000000" (I'm not sure) printf("%06x", a); displays "000064" Look in any C library manual and you'll find all the format codes. Cris
