Using PHY with RMII interface on Cyclone V SoC
- 7 years ago
I checked HPS EMAC spec as per attachment.
RMII is not supported in Cyclone V SOC. Yup, you need to write your own adaptor design if you insist to use it on CV.
Alternatively, you can switch to Arria 10 SOC or Stratix 10 SOC that support RMII.
dlim
There is FPGA IP that might do the job:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
Tutorials are also available.
1. About This IP Core
The Intel FPGA Triple-Speed Ethernet IP core is a configurable intellectual property
(IP) core that complies with the IEEE 802.3 standard.
It incorporates a 10/100/1000-Mbps Ethernet media access controller (MAC) and an
optional 1000BASE-X/SGMII physical coding sublayer (PCS) with an embedded PMA
built with either on-chip transceiver I/Os or LVDS I/Os. When offered in MAC-only
mode, the IP connects with an external PHY chip using MII, GMII, or RGMII interface.
The IP core was tested and successfully validated by the University of New Hampshire
(UNH) interoperability.
Johi.
