14 years agoUsing nios2-elf-gprof with UCOS-II?
Hello All,
Is it possible to use the Nios II GNU profiler with applications that use an OS (such as UCOS-II) with multitasking? I have followed the the "Profiling Nios II Systems" guide (unable to post link at the time - google title). However, when I execute the necessary commands, the gmon.out file is not created. Thus, I can not do any profiling. Here is what I have done: 1) Set enable_gprof and enable_exit to true in my applications BSP settings. 2) Regenerated BSP and re-built. 3) Opened two terminals, let's call them terminal A & B. 4) In terminal A, I executed the following command: --- Quote Start --- nios2-terminal --- Quote End --- 5) In terminal B, I then execute the following command: --- Quote Start --- nios2-download -g --write-gmon gmon.out my_eth_app.elf --- Quote End --- 6) I run my application and then exit with Ctrl-l C. 7) I then noticed that no gmon.out file is created. Is there something I am missing? One thing that the guide above states is to verify that your main function returns. However, in an UCOS-II application, main should not return as tasks are continually running. Typically, the UCOS-II API, OSStart(), is called from main, which starts multitasking and never returns. As an example of main, have a look at the code below.
int main (int argc, char* argv, char* envp)
INT8U error_code;
/* Clear the RTOS timer */
OSTimeSet(0);
error_code = OSTaskCreateExt(initial_task,
NULL,
(void *)&initial_task_stack,
INITIAL_TASK_PRIORITY,
TASK_STACKSIZE,
NULL,
0);
alt_uCOSIIErrorHandler(error_code, 0);
* As with all MicroC/OS-II designs, once the initial thread(s) and
* associated RTOS resources are declared, we start the RTOS. That's it!
OSStart();
while(1); /* Correct Program Flow never gets here. */
return -1;
As you can see from above, main will not return. Is this my issue? Do I have to look at other options to profile my application? Thanks for your help and I look forward to any feedback. -JQ5 Replies
please jq,
can you explain your solution (codes and tricks)?
best regards Edited... JQ, I understood your trick. Works fine here! Thanks! :)
dsl,
Thanks for your responses. I was able to get gprof to spit out the gmon.out by just placing an exit(0) function call after the portion of the code I wanted executed. I will say for anyone who reads this thread, make sure leave some time for the I/O to make it out of the JTAG UART before calling your exit function. For example, in my application (as well as in the "Profiling Nios II Systems" guide tutorial) a usleep function is called before the exit function call. This is necessary when using the profiler, because as soon as the BREAK 2 instruction is executed during the exit(), the application halts and the debug core takes over and transfers the gmon.out data back to the host. In my particular example, I had to invoke usleep with a larger tick count than what the tutorial used. When the tick count was too small, I would get the following error: --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Initializing CPU cache (if present) OK Downloaded 275KB in 4.7s (58.5KB/s) Verified OK Running target program until exit Uploading GMON data: 75% gmon data upload failed Leaving target processor paused --- Quote End --- However, when I used a larger tick count, gmon.out was created and uploaded back to the host: --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Initializing CPU cache (if present) OK Downloaded 275KB in 4.7s (58.5KB/s) Verified OK Running target program until exit uploaded gmon data: 28k in 0.8s Leaving target processor paused --- Quote End --- Again, thanks dsl for your responses and I hope this helps someone out there. -JQ - Altera_Forum
You need to look at the grof sources ....
Hello dsl,
Thanks for taking the time to reply. --- Quote Start --- IIRC the gmon.out file is usually written from a function registered with libc using at_exit() - so you probably need to call exit() somewhere in order to get those functions called (assuming that uCOSII will do it). --- Quote End --- I suppose what I can do here is just go ahead and hard card an exit function call into my source after I have executed the behavior I want to monitor (since ctrl-c does not initiate the dumps). I will update this thread when I try this. --- Quote Start --- Alternatively you may be able to directkly call the 'dump all the tables' command. --- Quote End --- I am not familiar with the 'dump all the tables' command. Is this specific to gprof? Can you post a link so that I can get more information? Again, thanks for your reply and I'll update this thread when I run my test. -JQ - Altera_Forum
Alternatively you may be able to directkly call the 'dump all the tables' command. Another possiblity is to request gcc add calls to profiling functions on every function entry/exit - and write your own stubs.
