14 years agoUsing nios2-elf-gprof with UCOS-II?
Hello All, Is it possible to use the Nios II GNU profiler with applications that use an OS (such as UCOS-II) with multitasking? I have followed the the "Profiling Nios II Systems" guide (u...
13 years agoplease jq,
can you explain your solution (codes and tricks)?
best regards Edited... JQ, I understood your trick. Works fine here! Thanks! :)
