DCamp13
7 years agoUsing Max10 ADC with PLL. Reset causes design to be unroutable.
Hello all, I'm working with the Max10(10M08DAF256C8G) and I'm trying to use the internal ADCs. I'm driving the ADC clock from a PLL. The problem I'm running into is I get the following error when...
sstrell
7 years agoMake sure you've set up the PLL parameters according to the ADC guide: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_adc.pdf
Did you turn off the option to have an areset input to the PLL? It doesn't look like it from your code.
