15 years agousing lvds
G´day !! I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This seri...
10 years ago --- Quote Start --- I'm testing LVDS module in Quartus II, can you tell me about implementing bitslip method? --- Quote End --- You don't need a bitslip module, as you can derive a signal from the FR-signal to clock the final two 14 bit words into to the original base-clock domain. Regards, Josy
