15 years agousing lvds
G´day !! I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This seri...
10 years agoHi josyb,
Thanks for you reply. --- Quote Start --- delivering two 14-bit samples every other base clock, --- Quote End --- Is here should be 7-bit? Do you have some thought about the synchronization among channels and devices? Can i use internal system clock as the shift-regiters clock? And the ADCs' DCO signals can't be routed to FPGA?
