15 years agousing lvds
G´day !! I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This seri...
10 years ago --- Quote Start --- Yes, it will. --- Quote End --- Hi josyb, Thanks for you reply! I'm going to using Stratix IVGX deivce, and have to use column I/O LVDS pairs to receive ADC output. I don't know the maximum speed of these column I/O LVDS pairs, and the datasheet only give the row I/O LVDS pairs speed range. Do you think the column I/O lvds pairs can run at 700Mbps or more than this speed?
