15 years agousing lvds
G´day !! I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This seri...
15 years agothanks guys for helping !
but now i´m a little bit confused about all that :-) 1.) serialization/deserialization, ok i misunderstood all that stuff 2.) i can type in the deserialization factor of 14 manually, and in handbook it´s mentioned "if the number is not available to choose, type the desired number in this box"! do u think that this won´t function? 3.) if it is possible to tpye in 14 isn´t it better to use lvds megafunction instead of ddio and shiftregister 4.) i if i use DDIO (it´s double data rate megafunction i reckon) and shiftregister (i suppose that this solution works without altlvds megafunction) i´m wondering if this also works with lvds input signals ??? greets
