16 years agousing JTAG and PS configuration
Hi ,
I plan PCB with multiple FPGA's on it. I want to have the opportunity to configure my board by JTAG and passive serial configuration with download cable ( and not configuration device). Some of The configuration pins are common for both configurations ( CONF_DONE, nSTATUS ) , and there is a little contradiction. in PS - all those pins connected together through 1 10 KOhm resistor to VCC. in JTAG- they are connected the same but each device has its own pull up network. I think that if I'll connect it like JTAG it will be fine and will also work for Passive Serial configuration, but I want to be sure. Another question I want to ask is , I want to have some visual sign that my devices work properly and when they finish configuration and start working. I want to do it with some led diodes , how would you recommend me to do that? Thanks , YanivNo RepliesBe the first to reply
