9 years agoUsing GPS with the De1-SoC...
For our application, position is important and we have procured a Globalsat BU-353-S4 The good news is the Prolific USB/serial port driver is visible... root@DE1_SoC:~# lsusb
Bus 001 Device...
9 years agoUpdate: I plugged the BU-353 into one of my debian boxes and did the following...
grunt:~# apt-get install gpsd gpsd-clients
grunt:~# dpkg-reconfigure
grunt:~# dmesg | grep ttyUSB
usb 1-6: FTDI USB Serial Device converter now attached to ttyUSB0
usb 1-9: pl2303 converter now attached to ttyUSB1
grunt:~# stty -F /dev/ttyUSB1 ispeed 4800
grunt:~# cat < /dev/ttyUSB1
... and out streamed lovely lines of GPS data. That was easy! That's is what I was expecting. So there is nothing wrong with the BU-353. One of the questions i have seen posted on the askubuntu forum (http://askubuntu.com/questions/30569/how-to-use-gps-receiver-bu-353) suggests if it is not working it might be a missing kernel module. Yes, the kernel spots the Prolific USB driver but does it need a special SiRF Star IV module that I might be able to find, compile & modprobe? Any ideas/help will be gratefully received.
