12 years agoUsing Fpga to HPS bridge
I have an ADC board connected to SOC kit and the FPGA recieves ADC samples at 10Mhz rate. I would like to transfer those samples to HPS and do some processing and send those processed samples back to fpga side of the device. I am not figuring out how to use the FPGA to HPS bridge to get those samples in HPS portion of the device.
i am also curious about this how to transfer a lot data between fpga and hps.
do you try about that fpga sava data directly through fpga-to-sdram master to DDR, then hps get data from sdram? - Altera_Forum
Still I haven't tried out accessing SDRAM from FPGA. But there is a sample script in Rocketboards.org that allows Fpga to interact with HPS DDR.
http://www.rocketboards.org/foswiki/view/projects/myfirstmodule
