16 years agousing extra space in serial rom
Hello, I would like some suggestions on whether the following is possible: I have a custom board with an EPC28 Cyclone II FPGA and a EPCS4 config rom. There is a single 10-pin connector to the ...
16 years agoI used the convert programming files tool to add the data files (in .hex format) to the .pof file and then I used the asmi_parallel block to read the data in user mode. Works just fine.
