12 years agousing epcs flash for both reset vector and store configuration
Hello all, I've tried to make a system in which the EPCS device would hold basically all information required for a working equipment. When implementing it, I couldn't open the EPCS device in N...
12 years agoThe fpga pins are configured correct (I assume) because I can program the flash memory using Nios Flash programmer. My problem occurs when I try to open the flash in the Nios program using
fd = alt_flash_open_dev("/dev/epcs_controller"); The file descriptor is NULL.
