12 years agousing epcs flash for both reset vector and store configuration
Hello all, I've tried to make a system in which the EPCS device would hold basically all information required for a working equipment. When implementing it, I couldn't open the EPCS device in N...
12 years agoI used this feature with 9.0 sp2 and it works.
Make sure you set the epcs pins with the "Use as regular i/o" option in Quartus project settings, otherwise fpga configures but Nios couldn't access epcs because those pins were reserved.
