12 years agoUsing CVO for NTSC output
Hi All,
I have a question that I have been battling for a couple of days. I am trying to use Altera's CVO IP to output NTSC video. I have tried to use the NTSC setting on the CVO but it automatically selects the Embedded sync options, but I need the sync signals on separate wires because my Video DAC requires the sync signals. This is the setup that I have: TPG -> CVO. I am using Quartus 13.0. Here are the settings that I am using for the TPG and the CVO. The pixel clock frequency I am using is 27Mhz. TPG settings: image width: 720 image height: 488 Bits per pixel per color plane: 8 Color space: RGB Output format: 4:4:4 Color plane configuration: Parallel interlacing: interlace output (F0 first) pattern: Color bars CVO settings: image width: 720 image height: 487 Bits per pixel per color plane: 8 Number of color planes: 3 Color plane format: parallel Interlaced video: checked Syncs signals: On separate wires Active picture line: 20 Field 1 Horizontal sync: 138 hfp: 0 hbp: 0 Vertical sync: 19 vfp: 0 vbp: 0 Field 0 F rising edge line: 266 F falling edge line: 4 Vertical blanking rising edge line: 264 Vertical sync: 19 vfp: 0 vbp: 0 pixel fifo size: 720 Fifo level : 719 I am not getting anything out on the screen with this setup. Can you guys shed some light on what I am doing wrong. Thank you for your help.No RepliesBe the first to reply
