12 years agousing altera FPL and choosing the configuration file in real time
hi, im using the altera pfl. the external flash stores 4 different configuration files. the flash is connecterd to max II cpld that responsible for the fpga configuration. my question is h...
12 years agoYou need to provision the bottom boot address into the CPLD before you initiate the FPGA boot. Assuming you have some connections from the cpu to the CPLD then you can use these to indicate which boot image to use. Alternatively, you may have jumpers connected to the CPLD with which you can specify the image you wish to boot the FPGA with. Either way, you will have to write some code for the CPLD to interpret the cpu signals or jumpers and provision one of four boot addresses.
The CPLD will then read the data directly from the FLASH, starting from your provisioned base address, delivering the bitstream to the FPGA via the configuration pins. Regards, Alex
