12 years agoUser POR?
I need something to use for a Power On Reset with the Cyclone II SDK. There is no external hardware POR input. Are the programming status signals CONF_DONE or INIT_DONE available to the user? Any ...
12 years agoIts pretty common for the development kits to have push-buttons, some even label the net for one of the push-buttons as cpu_rstN.
You can code HDL without a reset source, you just have to make sure you initialize the signals correctly, eg.,
signal count : unsigned(WIDTH-1 downto 0) := (others => '0');
process
begin
if rising_edge(clk) then
count <= count + 1;
end if;
end process;
The FPGA/CPLD configuration image will implement that initial condition. Cheers, Dave
