14 years agoUse spare memory in Active Serial configuration scheme
Hello, In my design I configure a Cyclone FPGA with a EPCS1 memory in the Active Serial scheme. I would like to use the free space of the memory for the application. Is there any document that tel...
14 years agoHello again.
First of all thank you rbugalho for your advice. I am now able to access the configuration flash from the FPGA without problems. I would like to preload the memory area that I am using in the application at programming time. Daixiwen mentioned a method to do so but I'm having problems to find a friendly manual or tutorial to learn how to do it. Do you know where can I find one? Or if it is not difficult to explain could you explain it for me? Thank you very much
