14 years agoUse spare memory in Active Serial configuration scheme
Hello, In my design I configure a Cyclone FPGA with a EPCS1 memory in the Active Serial scheme. I would like to use the free space of the memory for the application. Is there any document that tel...
14 years agoYou need to change the setting for the dual-pin purposes.
Device->Device & pin options But you should use the ALTASMI_PARALLEL function to access the PROM instead.
