14 years agoUse spare memory in Active Serial configuration scheme
Hello, In my design I configure a Cyclone FPGA with a EPCS1 memory in the Active Serial scheme. I would like to use the free space of the memory for the application. Is there any document that tel...
14 years agoThe FPGA image begins at address 0. If you use the programming files conversion tool (from Quartus' file menu) and generate a programming file for the EPCS1 from there it can generate a map file for you. It's a text file which says where all the flashed images are placed in the flash device. You can also use this tool to combine your FPGA image and your own custom data into a single programming file for the EPCS1.
