11 years agouse multiple clock drive in MAX II CPLD
I'm using my EPM1270T144C5 to implement a sinc3 filter to get my delta-sigma ADC result, and send the result to a DSP through it's external bus. As a result, I get two clock in my design one for the ...
11 years ago --- Quote Start --- Probably not. It will depend on the flow from the ADC to the DSP. For example, does the DSP respond fast enough all the time, or could there be a delay sometimes? Generally you would use a dual-clock FIFO. If the DSP could insert wait-states, then you would size the FIFO for the worst-case wait. Unfortunately you are using a CPLD that does not have internal memory, so implementing a FIFO will be expensive, i.e., it will use logic cells. Here's a good article on clock-domain crossing ... http://www.edn.com/design/systems-design/4333702/crossing-the-abyss-asynchronous-signals-in-a-synchronous-world If your ADC samples are really slow, then perhaps a simpler solution would work. Cheers, Dave --- Quote End --- The DSP read the bus every 62.5us and I get my ADC result updated every 25.6 us. Is there anyway that I could get my right ADC result without changing my cpld device? Thank you for your help.
