15 years agoUse DIMM with two DQS pairs swapped?
I have a prototype board that uses a DDR2 SO-DIMM. Due to a design error, the DQS6 and DQS7 pairs are swapped. Would the design still work? The DDR interface is very slow on this board and all...
15 years ago --- Quote Start --- By design do you mean on the PCB? just swap the entire DQ group pinouts in the FPGA design. --- Quote End --- IMO that won't work. The HPCII PHY makes use of the DLsL to phase-shift the incoming DQS signals on read. So the ALTMEM_PHY may get confused on initialisation. The best option to salvage the board is to write your own custom PHY using a PLL- generated phase to clock in the read data. At low frequencies this should be feasible, even easy at 125 MHz. If you feed the clock out on a free DPClk pin and route it back in (by forcing this in the Assignment Editor) the 'read clock' will track the silicon variation due to temperature and process quite close. But you may best first try the HPCII as is - using the heat gun to see if it holds.
