11 years agoUse Avalon MM Slave interface to connect to AXI Master?
Hello all! I recently acquired the SoCKit from Arrow and I am trying to make a custom project. I would like to create my custom VHDL PWM module in the FPGA, transform it into a Slave for t...
11 years agoThank you!
In case I want to use AXI, do you know if the H2F interface is compatible with AXI4? Or is it only AXI3 compatible. Again just for Control Register passing (setting the PWM module reference), not real throughput applications.
