12 years agoUse a high speed transceiver to transmit an arbitrary clock?
Hello, Is there a way to use a high speed transceiver on a Stratix V to transmit an arbitrary clock? I would like to create a synchronous high speed serial link between two boards, but op...
12 years agoThe output of a transceiver sending a continuous 0101 sequence without 8b/10b encoding could be considered as a clock, isn't it?
I presume you know that a transceiver can be clocked from a fractional PLL.
