14 years agouse 2 srams at the same time
hi:
I have writen some fixed data (1.2.3...) into a sram,then I want to read the data from it and write the data into the other sram at the same time.I write the code as below: begin SR1_wr_n<=1; SR1_addr<=SR2_addr+1; SR2_wr_n<=0; SR2_addr<=SRAM_addr+1; end assign SR2_DQ = (~SR2_wr_n)? SR1_DQ;16'bzzzz; then I look at the signaltapII waveform: I am sure I have write sram 1 correctly,but when I read the data from it,the data at adress1 should be 1,2,3...but it is 0422h,0423h,0424h... I am not sure if the method I used the two srams is right,that is ,reading one sram and write the other sram at the same time?? I give the attachment~ thanks very much!2 Replies
thanks for you answer!!~
I have find the reason,that is ,I have mistake the adress of SRAM - Altera_Forum
Please first try writing and reading only one sram properly. Make the display type according to your requirement, like HEX, Decimal, binary etc...
