USB to Ethernet Bridge via Cyclon10
Dear WeiChuan,
Thanks for your answer.
Yes I am concerned about the transmission speed and the cable length which exceeds 5m.
If you are concerned about the transmission speed and cable length. Technically, you can connect FPGA's anyway you want such as SPI, I2C, PCI, PCI Express, LVDS, DDR, etc.
For a slow-speed connection, you can use UART using two data lines + GND only to communicate between FPGAs.
If you need high speed, then you can use LVDS or some other transceivers with standard or custom protocol, provided the board and the FPGA supports it.
Anyway, ak6dn provides a good suggestion as well where you can take into reference/consideration
- Wincent_Altera4 years ago
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank youRegards,
WeiChuan_Intel
