sa261die
4 years agoUSB to Ethernet Bridge via Cyclon10
Hello community,
I ask myself if there is a way to transfer USB data via Ethernet. Here a host should be connected via USB to a FPGA, the FPGA should be connected via Ethernet to another FPGA and t...
Wincent_Altera
4 years agoHi,
I am WeiChuan from Intel Support team. There is multilple way to do that.
I might need to know more information about your system for us to provide the best suggestion.
- As stated in the description, can I know why you connect a few FPGA devices together using either USB or Ethernet?
- Why do you choose to connect FPGA1 via USB, while FPGA2 via ethernet? is there any transfer speed concern or it is based on design ?
- Is it possible to use USB-Ethernet Adapter ?
WeiChuan_Intel
