18 years agoUSB Device Controller ISP1362
I'd like to ask if anyone knows how to transfer more than 64 kBytes between the Device Controller (in chip ISP1362 placed on my DE2_Board) and the Host controller (my computer). I'm not able to write more then 64 kbytes into the buffer of the OUT endpoint. I access the register of the endpoints in PIO mode. Maybe I have to change the configurations of the 2 endpoints I use, for example to ISOCHRONOUS one (that i don't really know what it is)? I hope I have been clear enough, if anyone would give me even a little suggestion it would be a great help for me! thank you, Paola21 Replies
--- Quote Start --- Hello, I'm using the wsiausb of Tonyslagle. You search wisiausb.zip in the web and use the code in your DE2 o DE2-70 board. I am now working in a project which needs to make the DE2-70 board as a USB device and the host is the PC. When I try to probe the system, I found these problems: 1) If I connect both the blaster cable and the device cable to the pc or only the blaster, the host shows initially the blaster, then I download the firmware to the FPGA and the system do the Enumeration and initialization process and the ISP1362 is recognize by the host PC. But, if I disconnect the blaster cable, the system is not respond, then I reset the driver by the firmware and the device is doesn't show by the host. I am using the VISA USB Raw of National Instrument and its driver in the host. 2) If I work with both the blaster cable and the device cable connected, the system can transmit data from PC to device successful, but when I try to send data from device to host PC, it show me a timeout error. I check the firmware step by step and it apparently work correctly. Please, if you can probe and solve these problem, you say me.. Thanks... --- Quote End --- Hello, wsiausb project has a lot of shortcumings in its design - mainly the fact that if you compile it, the reported Fmax is lower than required for the desing to operate correctly. The fact that it works even sometimes can be just luck. Also, the state machine, designed part of wsiausb does not meet certain reset timing requirements (according to the Datasheet). I have used the code in wsiausb as a reference to develop my own project attempts to improve the things mentioned above. You can find it here: http://mzakharo.github.com/usb-de2-fpga/ - Altera_Forum
--- Quote Start --- hello all, I have DE2-70 board and I need to work with USB device.I am now working with a domo project "E2_70_NIOS_DEVICE_LED"on DE2-70 board.I download *.sof file and then in NIOS II IDE I build and run it.I think it should ask for driver for ISP1362 but it donot. I think my system should recognize USB-device as it recognize USB-Blaster.but it is not. I am lost and desperate.I have put my one week on it and no results. Pleaes guide me how you people working with it. give me simple tips and ideas initially to start working with ISP1362.I am not expert in c but I have much work with VHDL and FPGAs. Farhat --- Quote End --- Hi Farhat, Im currently experiencing the same problem like you, Did you solve that? Thanks, Ricardo - Altera_Forum
Hi summer,
I'm doing exactly what you did 2 years ago. " I'm modifying the coding from DE2 board CD -> DE2_demonstrations -> DE2_NIOS_DEVICE_LED." Instead, Im using DE2-70, but Im having trouble with compiling the project in NIOS II IDE 9.1. Did you have any issues with that? Is there any useful information about modifying the code that you could tell me ? Thanks Ricardo - Altera_Forum
hi,
I'm modifying the coding from DE2 board CD -> DE2_demonstrations -> DE2_NIOS_DEVICE_LED. For the firmware of device controller for ISP1362 chip, there got six related coding: MAINLOOP.C, CHAP_9.C, D13BUS.C, HAL4SYS.C, HAL4D13.C AND ISR.C. Where HAL4SYS.C and HAL4D13.C is hardware abstraction layer; ISR.C is interrupt service routine; CHAP_9.C and D13BUS.C is protocol layer; MAINLOOP.C is mainloop. Does anyone knows which firmware coding need to be modify and which one remains if I want to change the USB data block transfer to 16 bytes data block? Thanks and regards, Summer - Altera_Forum
Hi everyone,
i notice some of U had using the code from DE2_NIOS_DEVICE_LED demonstration(DE2 board CD) and modify it to send 64 bytes data . Can i know how you modify the coding? I'm using DE2 board, and i had modify the coding from ISR.c (void Isr_Ep01Done(void) ;void Isr_Ep02Done(void)) and mainloop.c (void config_endpoint(void)) but i still can't make it send 16 bytes data block. Please give me some suggestion...... thanks..... Summer - Altera_Forum
Hi! you can search in google or in www.sourceforge.net/projects/wsiausb/
That's a version 0.1. You should review, and debugg it. I'm working with that too. - Altera_Forum
Mr, I really can not find Tonyslagle wisiausb.zip drivers on the Internet !
Can you, please send it to me or tell me where to find them ? Thank you very much! Bojan - Altera_Forum
I'm using the wsiausb of Tonyslagle. You search wisiausb.zip in the web and use the code in your DE2 o DE2-70 board. I am now working in a project which needs to make the DE2-70 board as a USB device and the host is the PC. When I try to probe the system, I found these problems: 1) If I connect both the blaster cable and the device cable to the pc or only the blaster, the host shows initially the blaster, then I download the firmware to the FPGA and the system do the Enumeration and initialization process and the ISP1362 is recognize by the host PC. But, if I disconnect the blaster cable, the system is not respond, then I reset the driver by the firmware and the device is doesn't show by the host. I am using the VISA USB Raw of National Instrument and its driver in the host. 2) If I work with both the blaster cable and the device cable connected, the system can transmit data from PC to device successful, but when I try to send data from device to host PC, it show me a timeout error. I check the firmware step by step and it apparently work correctly. Please, if you can probe and solve these problem, you say me.. Thanks... - Altera_Forum
--- Quote Start --- Yes, I also want to have some guides to work with the ISP1362... Now I can read from the ISP1362 the packet from the host PC but I cannot send anything to the host PC (PC side receive no packet) --- Quote End --- People there, Since I have the similar goal (to use DE2 board as a USB device) I would really like some guidelines for ISP1362 controller. How to use it, how to program it... Please share with me any ideas... Regards, Bojan - Altera_Forum
Dear Farhat,
I also had a similar experience.I could not install the ISP1362 river for one month. I solved the problem recently. You try connecting both USB cables( Blaster and Device ) from the begining. Also do this while building the project.after build is complete rmove the USB cable from Device port aand run the C program, once u get a message chip ID XXX, u connect back the Device USB, your DE2 board will be detected by the OS as a new device and it will prompt you to install the driver. I hope this will help you... Regars, Mahesh
