18 years agoUSB Device Controller ISP1362
Hi, I'd like to ask if anyone knows how to transfer more than 64 kBytes between the Device Controller (in chip ISP1362 placed on my DE2_Board) and the Host controller (my computer). I'm not a...
18 years agoDear Farhat,
I also had a similar experience.I could not install the ISP1362 river for one month. I solved the problem recently. You try connecting both USB cables( Blaster and Device ) from the begining. Also do this while building the project.after build is complete rmove the USB cable from Device port aand run the C program, once u get a message chip ID XXX, u connect back the Device USB, your DE2 board will be detected by the OS as a new device and it will prompt you to install the driver. I hope this will help you... Regars, Mahesh
