14 years agoUSB Blaster Vs. Blue screen of Death
Hey guys, so I have Windows 7 professional and when I am installing the drivers for the USB Blaster I get the blue screen with error message of memory dump. anyone having the same problem? I had windows 7 home premium and was told that was my problem because it was doing it as well then, and when I got Windows 7 Professional it kept doing it.
Thanks6 Replies
Quartus does not require latest USB-blaster driver to work. You can install Quartus 9.1SP2 now. Do not reinstall USB-blaster. Bottom line,
1. Quartus 9.1SP2 for design entry 2. USB-blaster driver from 11.1SP2 - Altera_Forum
--- Quote Start --- 1. Remove all previous version + driver of Quartus II 2. Download the latest version 11.1SP2 3. Install drivers from# 2 --- Quote End --- Thank you so much did what you told me and it worked and installed the drivers perfectly as of right now. My school uses version 9.1 though can I know uninstall 11.1 and install 9.1 without affect the driver? - Altera_Forum
--- Quote Start --- Have they been Window 7 Professional 64-bits? --- Quote End --- Yes. Cheers, Dave - Altera_Forum
2. Download the latest version 11.1SP2 3. Install drivers from# 2 - Altera_Forum
Thanks for your reply btw. Gabe - Altera_Forum
--- Quote Start --- Hey guys, so I have Windows 7 professional and when I am installing the drivers for the USB Blaster I get the blue screen with error message of memory dump. anyone having the same problem? I had windows 7 home premium and was told that was my problem because it was doing it as well then, and when I got Windows 7 Professional it kept doing it. --- Quote End --- Which version of Quartus? I've installed several (newer) versions under Windows 7 and have not seen issues. Cheers, Dave
