12 years agoUSB Blaster Problem
I recently purchased the Cyclone II FPGA Starter Kit, but am unable to get the USD Blaster to work. The Quartus software is all installed, and I can write my code. When I plug in my board all of th...
12 years ago --- Quote Start --- I recently purchased the Cyclone II FPGA Starter Kit, but am unable to get the USD Blaster to work. --- Quote End --- This kit? http://www.altera.com/products/devkits/altera/kit-cyc2-2c20n.html Can you please see what the Windows device manager or Linux lsusb reports the USB-Blaster as. Sometimes these boards get shipped with the USB-Blaster not programmed correctly (blank EEPROM), and so you need to program it. I've posted the USB-Blaster images in this thread: http://www.alteraforum.com/forum/showthread.php?t=43986 You just need to download FT_PROG from the FTDI web site, use it to detect the USB-Blaster device (FT245B or FT245R), then apply the appropriate XML file, and program the device. Unplug and plug the USB-Blaster in, install the Altera driver, and you'll be all set! Cheers, Dave
