12 years ago
USB Blaster problem
I have a chip USB Blaster Rev C. When I program CPLD EPM7064SLC44-10 with Quartus II sp2 12.0 programmer, the process bar goes to 100% and then it shows "Failed". How can I fix this error ?
However, it works with ByteBlaster(Parallel port programmer).
Thank you.
    --- Quote Start ---
    Hi Yaroslav,
    What was wrong with the 74LVC125 on the SiLabs USB-Blaster?
    Your board should have already done that, i.e., the VCC_TARGET pin on the USB-Blaster is supposed to power the buffer inside the USB-Blaster. That is how the USB-Blaster ensures the logic levels transmitted to the board are compatible with the device.
    If your board did not connect VCC_TARGET, then that would explain the problem.
    Cheers,
    Dave
    --- Quote End ---
    Nothing ! My CPLD board is designed for ByteBlaster so it has 74HC244 on it to protect the CPLD. I tried to connect USB-Blaster to the same connector, but it did not work.
    About VCC_TARGET, I didn't know that's why I didn't connect it...
    Thank you,
    Yaroslav.
