HuaHongGan
2 years agoUSB Blaster II AS Mode does not go into user mode after programming
I run into problem where my board is not resetting to user mode after programming the POF file using USB Blaster II AS mode. I checked the board schematic and it is matched to Figure 8-6 under: http...
NurAiman_M_Intel
2 years agoHi,
Thank you for the update.
The only difference between USB Blaster I and II is their TCK clock speed.
-Have you try on different PC with the USB Blaster II?
-Howe many board have you try? Is this your own board or Dev kit?
-Can you also try using other board?
Aiman
