HuaHongGan
2 years agoUSB Blaster II AS Mode does not go into user mode after programming
I run into problem where my board is not resetting to user mode after programming the POF file using USB Blaster II AS mode. I checked the board schematic and it is matched to Figure 8-6 under: http...
NurAiman_M_Intel
2 years agoHi,
This can cause by the clock signal is not clean. Can you lower down the TCK frequency for the USB Blaster II to 16MHz or lower?
Steps below:
Aiman
- HuaHongGan2 years ago
Hi Aiman,
I am pretty sure I've tried that long long time ago and it doesn't work. I even lower the TCK clock speed to 6M, 1M and 100KHz. They all act the same.
Here is my TCK/DCLK signal (pin1) from the USB-Blaster II.
I got good 3.3V & I have lower the clock signal speed to 100KHz and still doesn't work.
Gan
