12 years agoUSB Blaster driver issue
I've been going through the forums and I have been unable to find an answer to my exact USB Blaster Driver issue. I have installed the free version of Quartus 13.1 and I now trying to use the USB Bl...
12 years agoReading through some advice, it said to grab the USBView application and look for the VID/PID of the device. Here is the output from this program:
Device Descriptor: bcdUSB: 0x0200 bDeviceClass: 0x00 bDeviceSubClass: 0x00 bDeviceProtocol: 0x00 bMaxPacketSize0: 0x08 (8) idVendor: 0x0403 (Future Technology Devices International Limited) idProduct: 0x6010 bcdDevice: 0x0400 iManufacturer: 0x01 0x0409: "FTDI" iProduct: 0x02 0x0409: "USB <-> Serial Converter" 0x0409: "USB <-> Serial Converter" iSerialNumber: 0x03 0x0409: "42424242" bNumConfigurations: 0x01 ConnectionStatus: DeviceConnected Current Config Value: 0x00 Device Bus Speed: Full Device Address: 0x01 Open Pipes: 0 Configuration Descriptor: wTotalLength: 0x0020 bNumInterfaces: 0x01 bConfigurationValue: 0x01 iConfiguration: 0x00 bmAttributes: 0x80 (Bus Powered ) MaxPower: 0x32 (100 Ma) Interface Descriptor: bInterfaceNumber: 0x00 bAlternateSetting: 0x00 bNumEndpoints: 0x02 bInterfaceClass: 0xFF bInterfaceSubClass: 0xFF bInterfaceProtocol: 0xFF iInterface: 0x02 0x0409: "USB <-> Serial Converter" 0x0409: "USB <-> Serial Converter" Endpoint Descriptor: bEndpointAddress: 0x81 IN Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Endpoint Descriptor: bEndpointAddress: 0x02 OUT Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00
