USB Blaster driver for Max+plus II
I received the MasterBlaster from the eBay seller. It is a complete kit, new in box, still sealed.
So I opened it up and it has both serial COM port and USB port interfaces, so I tried out the USB side.
I could not get it to be recognized on my Win10 QuartusII 13.0sp1 setup (that is the oldest I have).
Per the Altera documents Quartus 8.1 was the last version to support this device, so not unsurprising.
I did also open it up a take a picture of the PCB. It is an incredibly complex design inside, much more so than the follow
on USBBlaster/II series which was just an FTDI232 USB chip, an EPM7K cpld, and some buffers and drivers.
This MasterBlaster has a large FLEX10K FPGA, one appears to be a Motorola CPU, a large EEPROM, what appears to be a Cypress
USB interface, and a number of smaller buffers and logic devices. Backside is just a few small discretes. At the bottom is what
appears to be a 6-12V to 5V switching power supply (or it can work from the 5V USB power also).
So I can see why Altera EOLed this device in favor of the much simpler/cheaper UsbBlaster/II series PODs.
as mentioned above, it's unlikely that you can use MasterBlaster over USB with recent Windows versions because there's no driver for it. Use UART.
- Eagle_Savy2 years ago
Hi Gents,
Thanks a million for helping me along with this.
So, the advice from you would be to use this newly purchased Blaster with an old PC running WIN2K or WINXP the latest, or would there be another possibility?
@FvM : reading through the materials you kindly attached the link to in your previous response about the USB2LPT Conversion, I did not see any of the Altera listed in amongst the "Chip Programmers" tested. Would this be something I can consider using?
KR
Savvy_Eagle
