14 years agoUSB - ISP1362 flash logical addressing
Hello, I would like to understand how the ISP1362 (DE2-70 board) chip works. I read most of the documentation provided (the programming guide and the ISP1362 datasheet). After further fruitles...
14 years agoHi decebal and MMalik,
I'm also trying to figure out how does the DE2-70 USB works. I've also read the programming guide for the ISP1362 and took a look at the datasheet. I found out that the demonstrations of the Altera CD that comes along with the DE2 has an example of how to use the USB ( if you take a look at the project DE2-70_demonstrations/DE2-70_NIOS_DEVICE_LED). I'm still reading the code and trying to understand it. Mainly I want to know how to send data via USB to a host computer. decebal, have you found any other good material? Also do you have any idea how could I send data via USB, based on your reading of the programming guide? Thanks Ricardo
