15 years agoURGENT: Peripheral to Memory DMA Transaction
Hello, may I know how to transfer data from peripheral to memory using DMA? It is quite confusing from memory-to-memory transfer. please help! thanks!
15 years agonow i think i understand... correct me if i am wrong:
i connect two FIFO to x and y respectively, then 1 FIFO to result. the former 2 FIFO are connected to avalon bus. and the later FIFO is connected to DMA. am i right? when i see the pdf regarding FIFO, in the sample design, they use write control logic and read control logic, where FIFO is in between both logic. do i need write and read control logic in this context?
