15 years ago
[URGENT HELP] Add addition single Counter BIT HELP!
---------- Code Removed ----------
    You are using the push button for clk ?
    Is the led hanging on the most significant BCD (counts 10 , 20 , 30 , ...)
    or the least significant BCD (counts 1 , 2 , 3 , ... , 9) ?
    in this case (every 31 counts) u need to hang it on the least significnat BCD (in your image the lower one). In the other one LED will be left open.
    What happens is : The lower one counts every time u push the button.
    When it reaches 9 the uppen one goes one up. So the upper one counts every 10 times. If u place "if (count_counter=2) then ... " in the upper one, it will remain high for 10 times or from 20 to 29.
    Isn't it easyer to put the 2 BCD counters in one process? Or in one VHDL file.
    your code seems right to me except u don't reset count_counter
    it will count to 255 in stead of 31. Or u can make
    signal count_counter: unsigned(4 downto 0);
    If count is 31 next will be 0
    Why it remains high for 31 till 39? Don't know the code seems right. No time to test it on a testbench srry
    --- Quote Start ---
    This code is loop from 0 - 99.
    --- Quote End ---
    Can't be seen from the code.
    --- Quote Start ---
    The led will turn on from 30 - 39
    --- Quote End ---
    Not true for the shown code.
