15 years ago
URGENT: Flash memory
Hello. I am doing a project regarding DMA. However I need to use flash memory on the DE2 Board. I have done the instantiation for the flash but I cannot use because it always return zero for the function alt_flash_open_dev().
Spec:
Altera DE2 Board with 1Mb flash memory.
Can I ask if it is possible to have someone to provide me a sample simple C-programming code on how to use flash? Like from beginning such as from library part till the end.
Just a simple one will do. Because I tried so many but cant get it to work. I left lots of threads regarding this but none is helping.
My code just to test alt_flash_open_dev()
--- Quote Start ---
# include <stdio.h> # include <stdlib.h># include <string.h># include "system.h" # include "altera_avalon_pio_regs.h" # include "alt_types.h" # include "altera_avalon_performance_counter.h"# include "sys/alt_flash.h" # include "sys/alt_flash_dev.h"
int main(void)
alt_flash_fd* fd;
alt_u8 flashname[30];
strcpy(flashname, "/dev/ext_flash");
fd = alt_flash_open_dev("/dev/ext_flash");
if (fd)
printf(" -Successfully opened %s\n", flashname);
else{
printf("The end\n");}
return 0;
--- Quote End ---
Thanks!
    i think 20-bit should be fine because different size. Try change the setup time and hold time to 40ns each.
    Sir,
    Thanks for the reply. I have worked with all different timings, even though same result. My doubt about 22-bit is, it can assign only 4MB data using 8-bit data. How you are able to configure 8MB with 22-bit address? Another doubt is their any fixed Base Address for CFI Flash?
    Srinivas M
