15 years agoURGENT: Flash memory
Hello. I am doing a project regarding DMA. However I need to use flash memory on the DE2 Board. I have done the instantiation for the flash but I cannot use because it always return zero for the func...
15 years agoSir,
Thanks for the reply. I have worked with all different timings, even though same result. My doubt about 22-bit is, it can assign only 4MB data using 8-bit data. How you are able to configure 8MB with 22-bit address? Another doubt is their any fixed Base Address for CFI Flash? Srinivas M
