9 years agoup/down counter
Hello, can i get help for this program i am new to altera. i need help making a program that has an up and down counter from 15-0 using pushbuttons and 2 seven 7-segments display if its a...
9 years agoHello Malvin,
The second file is a module used in the first file. I think i went much further than i normally go to show you a path to find an answer to your question. I suggest you try to experiment a bit, make some changes and see where you get. Good luck, Johi.
