16 years agounused pin and Quartus option set
In the cyclone iii Pin Connection Guidelines, some types unused pins are recommended to connnect to VCCIO, and some are recommended to connnect to GND. I have two questions: 1. Which option shoul...
16 years ago --- Quote Start --- Choosing ''As input tri-stated with weak pull-up'' should be ok. That's the Quartus standard. --- Quote End --- this is actually dependent on the target device family. for example, Stratix II is default to driving ground. this is an important subtlety, especially when using development kits
