Unused Agilex F Tiles and recovered clk output.
You can follow the guidelines inside the document. If you are using FHT channel, then connect the pins as per suggested.
- emrahener3 years ago
My questions are on unclear statements on guideline.
13A and 13C has separate supply and ENB_GXF_FHT inputs. We are using All FHT13C but not using any FHT13A Rx/Tx. Guide line says if there is no FHT channel used. Given this fact can we connect 13A supplies and ENB_GXF_FHT input to GND?
Should we connect I_PIN_PERST_N_GXF to GND if F Tile is used but not as PCIE ? This is not directly specified.
Another question is on recovery clock output from F tiles. Is there a specific reason to have them as output from clk pins instead of routing them through fabric ? This is a question to minimize test connector cnt on out design If we can route the recovery clk through fabric I will mux recovery clk from multiple links inside FPGA and observe them on a single external connector. Is there a rule for their pin assignment when used for links with more than 4 differential pairs? Is it at the same frequency with the data rate or with the reference clk input? Is it LVDS?
