8 years agoUnexpected H2F-LW AXI Activity
I'm experiencing unexpected behavior on the H2F-LW AXI bus for the Arria 10 SoC SoM Dev-Kit (Achilles). I basically have a HPS-only example that includes DDR4, H2F-LW AXI port and a PIO-LED (output only) Qsys component connected to the LW port. This setup works as expected and I can toggle the LED(s) from Linux running on the SoC using the "/dev/mem" device interface. The problem occurs when I add the SPI (3-wire) Qsys component to the H2F-LW AXI bus. In this case, the PIO-LED continues to behaves as expected, but I also observe unexpected activity from the SPI-SCLK signal. After debugging further, I observed write assertions on the Avalon-MM bus in the SPI Qsys component. I attempted several modifications such as changing the base address, but nothing seemed to help. I'm not observing this behavior on the PIO component. Any ideas? Thanks!No RepliesBe the first to reply
